Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Attention Auto Geniuses, Nairb Is About To Lose It!!! Help!!!
Old 12-08-2005, 05:28 PM
NAIRB's Avatar
NAIRB NAIRB is offline
Guys,
I replaced the engine on a 1995 Mazda Melinia S. The engine is a 2.3 Millercycle with a lysholm screw type supercharger.
The engine will run and idle fine, but will not rev above 1500 RPM even if you hold it wide open.
This particular engine has a dual intake manifold system similar to a Ford 3.8/4.2, in that it switches a valve when you gun it to allow the supercharger to do it's thing.
I have checked exhaust backpressure, and fuel pressure. All within specs. The engine runs just the same with the exhaust removed so no plugged exhaust.
I need information if anyone knows where to get it. Desperate for help!
