Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Attention Auto Geniuses, Nairb Is About To Lose It!!! Help!!!
Old 12-08-2005, 05:55 PM
67 Deuce 4 Me's Avatar
67 Deuce 4 Me 67 Deuce 4 Me is offline
Bowtie or Die!
did you try manually squirting fuel into the intake while gassing it to see if it picks up? Mass air meter inst back wards is it? Any codes? Crank case over full? Will the ignition fire a spark tester? As I remeber from an old post I suggested you run from that thing! Its a pos. I hope some of this helps.
