Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Attn: Demon Owners
Old 07-28-2004, 05:13 AM
k-star k-star is offline
Last journal entry: PICTURE TEST
carb
You should go thru that carb and check all the gaskets, and pv, bolts etc to make sure they are all tight. Also to make sure there is no debris in the carb anywhere... Does it have the idle air adjustment in it?????
The timing deal will really help you out if it's retarded.. do you have the right heat range plug it in also?????
Keith
