Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Attn: Demon Owners
Old 07-28-2004, 08:52 AM
Miket Miket is offline
Re: carb
Originally posted by k-star
You should go thru that carb and check all the gaskets, and pv, bolts etc to make sure they are all tight. Also to make sure there is no debris in the carb anywhere... Does it have the idle air adjustment in it?????
The timing deal will really help you out if it's retarded.. do you have the right heat range plug it in also?????
Keith
It does not have the idle eaze feature. I will have to go back through the carb. Timing is at 16 BTDC...I don't consider it retarded but BG says it should be more----which means I have to to do somehting with MY HEI. Plugs are correct.
