Auburn Gear Limited-Slip for 12 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2012, 11:55 PM
igota66
Hi
I have 67 impala 12 bolt Rearend, with 12 bolt cover & 12 bolt ring gear with 30 spline axles and a 3.07 ratio.
I have brought a new Auburn Gear limited slip part No 5420106
The problem is that the ring gear is a fraction small in the centre to fit the Auburn centre.
Can I buy another ring & pinion the will fit the Auburn and allow me use the 12 bolt axle housing.
Cheers R
Old 01-08-2012, 02:49 PM
You will need to measure the interference.
The ring gear should be a light press fit on a GM 12BC.
Dont use the ring gear bolts you plan to install to pull the gear onto the carrier.
Old 01-08-2012, 02:57 PM
igota66
cheers for that imsport
I will Run a Mic over it tonight
it was just that I could fit the wheel over 2 others (tight fit) GM centers but not the Alburn
cheers R
Old 01-19-2012, 02:14 AM
igota66
All sorted
Warmed the ring a wee bit and on it went
10 bolt limited slip TpiRegal Transmission - Rearend 2 11-12-2011 07:09 AM
Auburn (Linited Slip) Instaltion Alaska_Man Transmission - Rearend 3 11-23-2010 12:40 PM
1979 10 Bolt 8.5 limited slip rearend greywulf Transmission - Rearend 3 04-25-2005 12:52 AM
Auburn limited slip posi jacobm99 Transmission - Rearend 2 01-25-2004 09:13 AM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 05:57 PM
