Which Auburn gear posi? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2006, 05:36 PM
77 Monte's Avatar
I just purchased a Auburn Gear Posi on Ebay. It came out of a 1987 Suburban. It looks brand new. It is a 10 bolt 8.5 " 28 spline. I tried looking up which one it is. There are two types. A professional and a pro series. Does any one know how I could tell the difference? Check out pic. Thanks
Old 02-01-2006, 11:39 PM
TechnTool's Avatar
OldSchool MotorHead
The difference between the two is going to be in the amount of torque required to slip the clutches. If it gives you a lot of tire scrub, then it is the pro model. I have driven Subs with the posi diffs, and they don't give a lot of tire scrub. One note, make sure you soak this unit in PURE friction additive for at least 24 hrs prior to installation. This is a MUST! MUST! MUST! do, if you do not, then you will have a royal me$$ on your hands, and a new boat anchor for your fishing boat.
Old 02-02-2006, 07:30 AM
Might contact someone at www.auburngear.com and see if there's any way to tell visually which one it its. Maybe a color code or something like that.
10 bolt Posi and gear advice? wickster Transmission - Rearend 4 05-20-2005 07:35 AM
gear and posi question red_rider52 Transmission - Rearend 17 01-14-2005 06:36 PM
auburn posi reliability. Jared Transmission - Rearend 3 05-10-2004 01:33 AM
posi? and gear ratio? jimos67rocks Transmission - Rearend 1 01-16-2004 06:53 AM
what is the gear difference on 10 & 12 posi 72 Z28 Transmission - Rearend 1 12-16-2002 07:29 PM
