Auburn gear question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 12:20 PM
77 Monte's Avatar
I just bought an Auburb Gear posi unit on Ebay for $280. It looks brand new but I think I got screwed. It is an 8.5", 10 bolt, 28 spline unit. The person I bought it from said it came out of an 87 Suburban. Here's the problem. On each end of this unit, bearings supposed to be press fitted. I have old bearings from another posi unit (same size, I wasn't gonna use them for this unit, I was gonna buy new) that I tried to fit by hand over the journals from this Auburn Gear, on the narrow side of the cone the old bearing would not fit over the journal, which is correct, they have to be press fitted. On the other end (wide end) the bearing slipped right over that journal and was even free wheeling (loose). My question is, does that mean this unit is junk, or is the wide end of the unit a fraction smaller than the other end? By the way, that's an actual picture of this unit! Jamie
Old 03-27-2006, 01:24 PM
Twistedwrench's Avatar
No officer I won’t do it again
I can’t answer your question but I can lead you to some experts that will. I purchase all my rear axles parts from this place. Contact them and ask for Craig or lorry. They are both great guys and will for sure be able to answer your question.
http://www.zbag.com/index.html 1-800-658-2537 Craig is ext 104 lorry 106
Old 03-27-2006, 01:59 PM
sbchevfreak's Avatar
Licenced Automotive Technician
For the money, I'd go buy a set of new side bearings and try them. the old ones may be stretched.
Old 03-27-2006, 05:01 PM
77 Monte's Avatar
Auburn Gear problem
That can't be it because I tested both bearings. Both are loose on wide end and both are tight on narrow end. Thanks anyway
first post-hello-timing gear question rsrogers Introduce Yourself 2 01-20-2005 01:50 AM
Gear Swap. M&M CUSTOM Transmission - Rearend 3 06-26-2004 06:53 AM
Camaro 10-bolt 8.2 upgrade - gear question EricTopless68 Camaro Transmission - Rearend 0 02-23-2004 10:10 PM
hi, i have a rearend gear question Thuggishruggish3000 Transmission - Rearend 2 08-10-2003 01:55 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 06:08 PM
