Auburn (Linited Slip) Instaltion - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2010, 05:44 PM
Well, I got the new Auburn unit installed in my 85 Chevy (2-wheel drive) truck yesterday. All went well excipt getting the chims in. Tough to do when you're by yourself. Took it for a little drive last night and it feels and sounds good. Was going to take it out for a 10 or 20 mile run today but, it started to rain last night and now we have nothing but "black ice" eveywhere. So decided to to waite for better weather. But, I have one question, in the instructions that came with it they said after you get the mesh set right, add another .008, to the shims, .004 to each side, to "preload" the carrier barings. Anyone know what's up with that? I don't think I have room for another .008 in shims.
Old 11-22-2010, 06:58 PM
big gear head's Avatar
High Performance Rear Ends
You just need to get the shims as tight as you can without damaging the shims or the housing. If you can tap the shims in without bending them or shaving metal off of the housing, and you can't pull the differential out by hand then it's tight enough.
Old 11-23-2010, 10:06 AM
Thanks
Just wanted to say thanks to all that helped me in this little project and a really big thanks to BGH. You have been right on with everything you've stated here. Thanks.
Old 11-23-2010, 11:40 AM
Glad to help.
slip yoke doesn't (slip) on... markzepp820 Transmission - Rearend 14 04-29-2008 01:29 AM
posi = limited slip, right?? bigwildgrin Transmission - Rearend 6 01-07-2007 11:48 PM
Auburn limited slip posi jacobm99 Transmission - Rearend 2 01-25-2004 08:13 AM
Want to go from 2:43 limited slip to 3:73 limited slip Bradless Transmission - Rearend 2 01-03-2003 10:12 PM
