I'm starting this thread basically to point to another thread http://www.hotrodders.com/forum/meaning-these-electrical-terms-118984.html so that the information will be easier to find with this more appropriate thread title.
I run an Audiovox CSS 100 Cruise in my '32 pickup and recently installed LED rear tail lights. Shortly thereafter I discovered that my cruise control no longer worked.
After three days of thrashing (and lots of help from Doc, Rob, and others here at HR.Com) we discovered that the Audiovox will not operate without regular, incandescent bulbs (or comparable resistors) in the wiring for the rear brake/turn signal wiring system.
So if you are contemplating this particular combination of parts (Audiovox cruise and LED lights) read the thread I linked above and it will give you all the dope on making this setup work.
BTW, no one needs to respond to this post. Just use it as a pointer to the other info.
