Auto Air Candy - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 07:16 AM
Registered Novice
Auto Air Candy
Hi,
I understand I should reduce the AutoAir Candy colours 3:1 with the AutoAir Flash Reducer 4011.
Do I also need to add the Transparent Extender/Base 4004 as well?
Old 06-15-2010, 10:47 PM
Registered Novice
Am I in the right forum?
Old 06-15-2010, 10:50 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I would say that yes, you are.
I would imagine that someone will eventually read this and get you the information that you need.
Old 06-15-2010, 11:13 PM
66GMC's Avatar
I'm no expert, by any means ... but I found these on their website.
Hope this helps.
Looking up the details on #4004:
4004 Transparent Base
Colorless base to all Auto Air Colors.
Reduces concentrated 4600 Series Candy Colors.
Use as inter-coat with minimal build. Although not necessary, Transparent Base can be used as a protective inter-coat. Apply in very light amounts when doing so and allow for extended drying time. Inter-coat of Transparent Base over coarse 4400 Series Gem and 4500 Series Hot Rod Sparkle Colors assists top-coat clear in bridging over colors’ pearl-flakes. A little goes a long way when using Transparent Base as an inter-coat clear. Apply it as a drop coat. Do not “paint” it on with any significant build-up of material.
Add to colors in any amount to increase transparency.
The use of it as an inter-coat clear is also mentioned in the Application Guide
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Runs Like Crap With Air Cleaner On - why? leejoy Engine 30 11-16-2010 07:08 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
shooting clear vinvango73 Body - Exterior 3 10-29-2005 12:24 AM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 06:52 PM
