Auto change to standed - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2009, 07:31 PM
brian berwick's Avatar
Looking for info on how to change 1996 Blazer to a 5 speed.The 5 speed is out of 1989 s15 pickup.It is going to 2.5 liter 2 wheel drive just trying to make sure the pedals and hydraulic clutch from pickup will fit they came from s 15 Any info would be great
Old 10-04-2009, 12:04 AM
You could make it work, do you have all the clutch pedals, etc. from the other blazer still? The tranny should bolt right up, and is the 96 a 4wd?
Pulley Change Out Long to Short Water Pump Mule Engine 7 05-25-2007 07:06 AM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
Can I change from a 28 to 26 spline carrier? artillerystevens Transmission - Rearend 0 03-05-2007 11:53 AM
Small base circle cams / pushrod length change??? hotrodf1 Engine 1 12-05-2006 10:49 AM
Auto Refinisher Jim B. Body - Exterior 4 05-29-2006 01:48 PM
