auto classic - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2013, 04:28 PM
auto classic
hi I am new to forum I am having problems with water in my air compressor system. can someone help with piping or dryer to solve this problem. thanks 61con
Old 11-07-2013, 05:43 PM
If you have moisture in the freon you need a new dryer.But when you replace it also try and remove all the oil and flush the system. Replace the oil by weight and the freon also. Is this a factory air or after market air?
Old 11-08-2013, 04:05 AM
astroracer's Avatar
Is this an AIR compressor for running air tools and paint sprayers? What does you "system" consist of? Long runs of air hose or hardlines? You need to run a water separator out at the tool end. If you are using long air lines this is your only recourse. If you are using hard lines the same thing applies but it can be mounted to the wall with a short line to the tool. You may still have to run a small separater out at the tool just to keep the air dry.
Mark
Old 11-08-2013, 03:19 PM
Mark
yes this is for air tools. my system consists of water separator right out of compressor and then to hose reel mounted to floor. thank you for your reply dave
Old 11-08-2013, 07:52 PM
astroracer's Avatar
No problem Dave. Move your separator to the other end of the hose and you'll be good.
Mark
Auto. Day time running lights and auto. dash lights. shee4202 Electrical 2 08-28-2012 09:21 PM
Pure auto porn, naked auto porn. :) MARTINSR Hotrodders' Lounge 1 08-09-2011 12:32 PM
Auto Tech vs. Auto Body Career? mgold Hotrodders' Lounge 41 01-04-2010 07:36 AM
Classic Auto Restoration classicautoresto Introduce Yourself 7 04-16-2009 07:51 AM
New Age Auto ABC Soup (think 442, GTO, R/T=old auto ABC soup) ChevelleSS_LS6 Hotrodders' Lounge 5 08-23-2005 08:22 PM
