Auto on the column - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2005, 07:11 PM
Derkyb's Avatar
Auto on the column
Anyone heard of a reverse lockout for an automatic column shift? I would like to try to keep it original looking and still have the confidence of shifting without going into reverse. I was thinking about puting a B&M shifter on the floor, but I have a bench seat and dont think it will look to hot.
Old 11-13-2005, 08:38 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have never heard of a lock out for automatic on the column.
Old 11-14-2005, 01:03 AM
For the 2-3 shift on a column-shifted Turbo 350 or 400, I've always used a quick up-down kind of a slapping motion on the shift handle. Hold your thumb below the handle & your fingers above it, then slap it upward with your thumb and then down quickly with your fingers, as close to a single motion as you can. It should land in Drive. Might take a little practice, but it works for me.
Old 11-16-2005, 07:30 PM
Derkyb's Avatar
Ok I will try to practice that and see how it works. Something else I was thinking about was putting an electronic shifter solenoid on it and when I go racing just push the button. However, I havent found anyone who makes that kind of solenoid to select the exact position for the trans detent. If anyone has heard of such or knows how to rig up something like this please let me know. Thanks
GM steering column tilt/wobble repair HELP (pics inside) camaroguy1969 Suspension - Brakes - Steering 18 03-05-2009 01:37 AM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 02:06 PM
custom steering column Blob Suspension - Brakes - Steering 5 07-08-2005 02:28 PM
GM Column Wiring - Help Please Centerline Electrical 1 04-15-2005 06:29 PM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 07:56 PM
