auto darken weld helmet question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2013, 08:57 AM
What's the safest way of testing the lens to make sure it's working ? I can get it to darken some if I hold it near the floresent lite , it has new batteries. Thanks
Old 09-29-2013, 09:50 AM
Last journal entry: New Rev wheels and BFG KDW II tires
I think you answered your own question. Holding the lens to a bright light should make the lens switch over.
Unless it is a very cheap lens and doesn't have good sensitivity it might not switch that way. Then you could try welding with it without looking directly at the weld and you would know right away if it was working or not.
The Following User Says Thank You to 64SS327 For This Useful Post:
f/bird (09-29-2013)
Old 09-29-2013, 10:02 AM
techinspector1's Avatar
Wiki Edits: 326
Looking at the sun should do it, wouldn't you think?
The Following User Says Thank You to techinspector1 For This Useful Post:
f/bird (09-29-2013)
Old 09-29-2013, 10:06 AM
I use a 3m helmet so I'm not sure how a cheaper helmet would react. It should switch if it's not broken.
What kind of helmet is it?
f/bird (09-29-2013)
jonahb's Avatar
That is 100% right unless you have something like "x-mode" (electromagnetically senses the arc) on your autoshade it should darken when looking at the sun.
The Following User Says Thank You to jonahb For This Useful Post:
f/bird (09-29-2013)
Old 09-29-2013, 01:56 PM
It's a speedglas 9000
Old 09-29-2013, 06:41 PM
My autodarken helmet will even switch to dark looking directly at an incandescent lamp, and wave my hand in front of the helmet, to briefly put a shadow on the sensors.
Looking at the sun is not going to work here in Oregon until about next April!
The Following User Says Thank You to DanielC For This Useful Post:
f/bird (09-29-2013)
Old 09-29-2013, 07:03 PM
This was an easy fix for a change !The NEW batteries I put in 2 wks. ago were actually bad. The helmet had been in the box almost 2 years and not used as we had moved and I had to wait for my shop and the electrical to get finished so I bought some batts and installed them . Good thing I just put the old ones in the bottom of the box ! They still work ! I automatically thought it was broken after setting so long and moved all over . Thanks for the response everyone !
Old 09-30-2013, 07:22 AM
Wiki Edits: 27
good cleaning
Every so often I take my helmet apart and clean everything, they work a lot better when you get all the smoke stain off.
The Following User Says Thank You to timothale For This Useful Post:
f/bird (09-30-2013)
Old 09-30-2013, 01:06 PM
My problem is not using my tools enough to keep them working . Due to health problems I'm limited as to how much I can use them but if I didn't have them I'd be trying to get someone to do these little jobs all the time , I have to pick the things that surely is not needed right away LOL ! The helmet was in the box almost 2 years !!!!! Thanks for getting back !!
Old 09-30-2013, 08:44 PM
ogre's Avatar
the 'Duracell Project'
i have a harbor freight autodark helmet at the house, i do most of my welding at the shop anymore.
if i don't use it much in a year, it sometimes fails to darken.
i lay it out in the sun for a day and it works fine after that.
the batteries must be charged when welding, laying it out in the sun must charge the batteries
The Following User Says Thank You to ogre For This Useful Post:
f/bird (09-30-2013)
Old 09-30-2013, 09:15 PM
I hear all the time how HF stuff is not worth nringing home. When my son in law was here I borrowed my neighbors HF aut helmet for my son in law. That 39 dollar helmet put my 120 dollar helmet to shame.
Agreed, much of what they have is not great quality but there are things that are very much worth the money. Especially for we non professionals.
John
Old 03-07-2014, 10:37 AM
67chevytruck's Avatar
Just look at your phone screen, Itll trigger it because most phone screens are UV light, same as what triggers an auto darkening.
Old 03-11-2014, 09:19 AM
put up or shut up
I love my Nitro. If the screen goes bad you can replace it. It has shade settings and time settings. If I use a grinder it will darken before even seeing one spark. 10 years running and no sign of let down. great investment. $169 but well worth it.
Old 03-11-2014, 08:29 PM
Put the helmet on and point a TV remote control at it and push some buttons on the remote. The remote puts out Infra Red which will trigger the auto darken function.
The Following User Says Thank You to '48 Austin For This Useful Post:
tech69 (03-11-2014)
Northern Tool auto-darkening helmet 1meancuda Garage - Tools 11 09-27-2009 10:30 PM
auto darkening helmet tcoop Garage - Tools 12 04-12-2009 06:30 PM
Auto dimming helmet chas350 Garage - Tools 37 10-25-2008 11:11 AM
Auto Dim Welding Helmet BadHabitSS Body - Exterior 35 12-17-2007 09:06 PM
Auto Darkening Welding Helmet JamieK Garage - Tools 39 08-21-2007 04:33 PM
