Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Auto-Darkening Lens and Halogen Light.
Old 02-08-2009, 08:42 PM
scrimshaw scrimshaw is offline
Last journal entry: More painting pics
Originally Posted by oldred
Is it possible to set that light close to where you are working? If you put it so that it illuminates the work but you are actually behind it you may find that the problem will disappear plus the added bonus of being able to see the weld better. I know several people who do this when welding body panels just for the improved visibility at the arc since it helps to eliminate one of those helmets' annoying characteristics, the fact that they tend to get so dark right at the weld it makes it hard to follow a seam. This probably would make little difference with a conventional lens but because of the way these things work changing the contrast by using a bright light will help quite a bit with the auto Dark helmets.
Will try this tomorrow and let you know how it works. Thanks.
