| Register now (free) or login to remove ads | |
Tweet
#1
auto darkening welding helmets
Is a $180.00 auto darkening helmet from National Welders that much better, than one for $60.00 at Harbor Freight or Northern Tool?
Is there a quality or safety issue between them? Thanks |
| Sponsored Links |
#2
Well you do kind of get what you pay for but both will work I have found that the higher end hoods have much more adjustment which is good for TIG work. But for Arc and Mig I don't see much difference but I have had some guys complain about eye strain using the cheaper version due to the slower reaction time but it is hard to believe. I personally finally ponied up and bought a good Miller hood and love it just my opinion hope it helps I am sure I will get corrected tho! |
#3
Most of the quality difference is in the shell and headband and the HF helmet has the same "Chameleon" lens found in some "brand name" helmets. Although I think the Hobart/Miller helmet, the one called "the hood" by Hobart, has a different lens than they had about 10 years ago, they did at that time share the EXACT same lens as the HF helmet. I have seen and used the HF model and it definitely is a good one for the money but the headgear is a bit flimsy although the lens is about as good as any I have tried. I had the older Hobart outfit and I now use a $400 Jackson which is top quality and has a few extra features but the HF helmet functions just as good as for lens function. If safety is the main concern then don't worry about the HF outfit because all of these auto dark helmets have to meet the same government mandated safety standards. Also you can ignore those goofy urban legend sob stories about some poor worker who went blind because he was forced by his employer to use a faulty auto dark helmet that failed to darken fast enough.
#4
http://cgi.ebay.com/ebaymotors/WELD...sspagenameZWDVW
Bought this one after burning my eyes last year. Used it for arc and mig. Works better than I expected. Only thing I dont like about it is the fact that the battery is not changeable. It has a lithium battery that is recharged by the solar panel. but for $50 I can buy a new one every few years. |
#5
I have one of the expensive self darkening helmets and used it for years....... Till I found a simple photoelectric self darkening helmet at HF for about $40. No batteries, it adjusts from 10-12 and works like a champ. Next time I'm down in the valley at HF I'm going to pick up another just to have as a spare.
#6
I have the same HF helmet,I like it.It works very well.I too will buy another one if mine goes out. |
#7
Thanks to all for the replys. Looks like i will be headed to HF soon.
#8
I have a Miller auto dark and just got a new job TIG welding and Mig welding. Mostly stainless steel. The problem is that the welds are on 3/4 to 1 in material and the darkest setting is still about 1 shade not enough. After the 2nd day my eyes are really tired. It's hard switching from one process to the other but the auto dark is easy to adjust. It's just the MIG on the thick stuff is really bright. I even tried adding sunglasses but if anything they made it worse.
I used a whole spool of .045 wire in 4-5 hours. It's almost non stop. Then switch to tig. I'd guess at least 5 pounds of rod. They told me there is an even bigger job coming. |
#9
listen to oldred when it comes to anything concerning welding. i bought an auto darkening welding helment off fleabay, but i could have bought the same helment from HF a few months later. they are regulated by our guberment, oldred is the guy who knows when it comes to welding...
#10
I LOVE my HF helmet!
#11
My northern tool helmet cost like $49 and changes to full dark in like .0000000025 seconds, no way is that too slow.
I think I would be more likely to strike an arc with a normal hemet up than have this one fail. My cousin owns a shop and bought a $250 helmet, the diff is all in the quality of the straps and materials, not in the lens Keith |
#12
auto darken helmet
I have several helmets and the problem is one of them has an on button that I sometimes forget to push they all work ok for me except the flash from forgetting to turn it on.
#13
I have bought a couple of the cheap helmets over the years...
I found them to work very well, However: my only advise is to buy the SOLAR powered one that does not use batteries. the battery ones have a power saver that keeps switching the helmet off and that is a pain in the butt! ALSO....make sure the lens darkening control knob is on the outside of the helmet so you can easy adjust w/out taking helmet off. ps: the solar unit works real good in low light conditions as well... |
#14
There are a few others here also!!!!
#15
Thanks for all the help on this. Seems like a HF helmet is good, but I need to find one that is solar powered and not battery. Thanks again for the help...
| Similar Threads for: "auto darkening welding helmets" | ||||
| stick welding question | powerrodsmike | Garage - Tools | 51 | 05-12-2008 12:01 AM |
| ~ MIG WELDING - The DIY Guide. | Sanctifier | Garage - Tools | 4 | 04-23-2008 04:34 AM |
| Auto Dim Welding Helmet | BadHabitSS | Body - Exterior | 35 | 12-17-2007 10:06 PM |
| Refresher: welding 101 | Gr8 '48 bow tie | Garage - Tools | 12 | 03-09-2006 01:40 PM |
| Parasol Metal body filler. | x711 | Body - Exterior | 16 | 02-14-2006 10:47 AM |
