Auto-Drone tach wiring ideas? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2005, 10:41 AM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
This is from my older brother's first car, a 85? Chevrolet Celebrity; 2.8Lv6 (fuel-injection), and the speedo didn't work so dad got him this here tach and used it as a speedo... (in gear A at RPM B = X mph kind of a deal)
Well, 2 weeks after my brother got the car I was with him going down a dirt road and he decided to be stupid with it and well we hit a tree and junked out the car. I guess it's better he killed it that way since he probably would've thrown a rod sooner or later with how he had a habit of revving the daylights out of it (6500rpm). Anyways I removed the tach before it went off to the iron graveyard.
Back to subject... a friend of mine has a 87 Dakota (3.9v6, carb) and we were going to use it to set idle speed.
Problem is, we don't know how to hook it up.
There's 2 red, 1 black, and 1 green. I do believe it has a little backlight fyi.
thanks!
-matt
Old 12-12-2005, 04:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Red=Power
Black=Ground
Green= Coil
That should do it...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 12-12-2005, 07:22 PM
TechnTool's Avatar
OldSchool MotorHead
The Green wire goes to the Negative side of the coil. Some ignition modules are very picky about loads on the Positive side, so be careful not to mix them up.
Old 12-12-2005, 10:08 PM
Wiki Edits: 7
Wowza, Doc is "Our residential electrical expert" as I've heard him described before.
And TechnTool provided a valuable piece of info also.
Thank you both
-matt
Old 01-19-2011, 09:40 PM
Wiki Edits: 7
I was looking at this, and sure this is an old thread, but why does my tach have 2 red (power) wires? Just seems strange. Wish I thought of that when Doc was around.
RIP buddy
Old 01-20-2011, 08:26 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
You are still working on this 5 years later..? That is a long time for a tune up, hope you are not charging your friend by the hour..
Tach wiring 72chevelleguy Electrical 2 03-11-2005 08:43 PM
sun super tach 2 wiring tachproblem2 Introduce Yourself 1 01-30-2005 05:19 PM
Sun Tach. Wiring Help 383vette Electrical 4 10-02-2004 03:00 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 08:28 PM
Wiring up a Tach ...... TheZaZ Engine 0 03-25-2003 07:26 PM
