auto gauge wiring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2009, 12:06 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok I'm thinking about buying an autogauge 5in tach with shiftlight its the auto meter series.right now the guy has it hookd up to his msd box. I've never done one of these before will it be hard to install it? .
Old 12-11-2009, 07:28 PM
No, this is not hard. You hook the tack to the out put signal of the msd box.
Old 12-11-2009, 09:31 PM
two cups of tea
Wiki Edits: 2
But I don't have an msd system
Old 12-12-2009, 10:09 AM
Joe G's Avatar
If your engine has an HEI distributor, you will connect the tach signal wire to the tach output terminal on the distributor. If you have a standard points-style ignition system, you would connect the tach signal wire to the (-) coil terminal.
question concering wiring a tach tom penicaro Electrical 1 10-08-2009 11:52 PM
Auto meter Wiring 78Z Electrical 7 09-02-2009 07:02 AM
Question about fuel gauge ??? Robbie Electrical 4 06-06-2009 08:31 PM
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 01:50 PM
Gauge Wiring alf1096 Electrical 2 06-16-2005 08:22 PM
