auto to manual tranny conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2008, 02:30 PM
how do i convert my automatic to a manual tranny? i have a m21 4 speed. what parts do i need?
Old 05-11-2008, 09:05 AM
maybe a silly question but what kind of car is it? basically you'll need to get clutch pedal assembly or make your own, a zbar, possibly modify the crossmember, possibly modify the driveshaft, most likely cut a hole in your floor, change your flywheel and depending on the car there could be other considerations
Old 05-11-2008, 09:44 AM
With a screen name of Crazynova2007 ... it would stand to reason that you have a Nova ... but which year??
The early Novas ( 62 to 67 ) have to have a special piece added to make the Z bar work. 68 up models are much easier to convert to manual.
1) manual flywheel
2) clutch and pressure plate
3) bell housing and arm
4) throw out bearing
then
5) all the clutch linkage ( pedal, brackets and such ) ... preferably from a donor car
That's just the major pieces ...
Old 05-11-2008, 09:57 AM
manual tranny
its a 1970 nova.
Auto to manual conversion cbrchamp Electrical 8 04-10-2008 07:49 PM
changing tranny from stick to auto chronos Transmission - Rearend 7 06-23-2007 04:14 PM
Manual Transimission Conversion Tissue Transmission - Rearend 4 12-14-2004 04:18 PM
auto to manual tran converson Reggie Berry Transmission - Rearend 1 08-15-2004 06:10 AM
Manual transmission conversion kemo Transmission - Rearend 0 12-04-2002 01:25 PM
