Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Auto shifting to quick!
Old 11-23-2002, 03:32 PM
Dave E Shank's Avatar
Dave E Shank Dave E Shank is offline
Post
Hey Chevelle: I had that same problem on a TH 350 that I had put a shift kit in. As soon as you would take off it would up shift before building RPM. It would also hunt when driving about thirty MPH. I found out that when we installed the shift kit on of the check balls had moved into another circuit and was blocking fluid flow. I bought a Transco kit from Sumitt Racing and it cured the problem. GOOD LUCK DAVE SHANK
