I have a 69 chevelle with a th350, when i have it in drive(3rd) and floor it it shifts way to fast out of first, it doesnt go past 3 grand. it takes off then shifts and the rpms arent up enough and so 2nd starts to early and it slows down then starts gainin speed. but if i have it in 2nd it will go to 4 or 5 grand in first then shift. does anyone have a clue what is the problem. is it my kick down or something in my transmission?
Have you looked at your govenor assembly? I would say that is a good place to start. Did it happen out of the blue?
its been goin on for awhile. but ill check those things.
327, Do you have an adjustable vaccuum modulator on your trans? You will get an early shift if the adjustment is wrong.
i dont know about that vacuum modulator. but ill try what shank said because it does have a shift kit. i think i found a transco kit, but its called transgo is this right? it seems like it is another shift kit that id have to put in.
