Auto tranny for 392 Hemi - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2002, 10:40 AM
Post Auto tranny for 392 Hemi
I am installing a 392 Hemi in a 32 Ford Coupe. I would like to use an automatic transmission. I know that a 727 torque flight will work, but I have been told that there is an adapter plat that will allow the use of a turbo 400 has any one done this? Do you know were I can buy the plate? How does it work well? Will it fit in a Downs Body with a 3" recessed fire wall with the K member in the standard position?
Tahnks for your help !!!!
Old 03-23-2002, 11:56 AM
Wink
Contact "WILCAP" engineering or Capanna Co. They have internet sites. The make the Adapter for Chrysler 727 or GM Powerglide, turbo350/400, 700r4 and I think the adapter is about $375.00.
They also sell a oil filter adapter that is a must with this engine (392) in a 32 Ford Frame or you can make one from a oil filter flange off a Ford 360/390 engine. GOOD LUCK!
Old 03-23-2002, 02:32 PM
Wiki Edits: 49
Thumbs up
Wilcap makes an excellent product. I'm using one of their adaptors for a Th-350/400 on a Chrysler 331 I'm installing in a 53 Chevy pickup.
You can order the adaptor with left or right side starter depending on your needs and they also come with the flex plate.
[ March 23, 2002: Message edited by: Centerline ]
[ March 23, 2002: Message edited by: Centerline ]</p>
