I think you've answered your own question. BUT, if you use the 200R4 you won't have to change out or shorten your driveline. You may have to change out the slip yoke, depends on what trans you have now. It would be best if you sidemounted the engine, and you'll need a trans cross member; if you already have a trans cross member, it will need to be moved back to line up with the 200R4. You could also keep your front mounts (if that's what you have now), use a trans cross member, but also mid mount the trans at the bellhousing. All these are available from any of the tri-five vendors. The throttle valve linkage on the 200R4 or the 700R4 is a critical adjustment item.
56 chev auto trans?
Thanks for your reply junior stocker. I have a couple more questions.
Do you or any other member know where to buy a rebuilt 2004r or700r4 at a decent price? And do you think these are my best trans. options or is there another trans. you would recomend? Also, I need a torque converter and was wondering if the $110 ones seen on Summit site are really ok for just my type of cruising to the store and around town and not racing etc. ? Also, you mention installing the cross member under the bell housing allowing the use of current motor mounts, is that right. Thanks |
The cross member would be installed at the transmission mount on the extension housing. IF you have stock type front mounts in your car, then with the engine mounted at the front and the trans at the rear, it makes for a lot of stress to those components, over that distance; so you would want to also support the "middle" somehow, ie. with what are called mid-mounts. Most guys will convert to side engine mounts and a transmission mount/crossmember (a 3 point style mount) like a more modern car/truck. I said go with a 200R4 because you have a 283 and were'nt interested in a "hot rod". If you ever plan to go to a larger CID engine (like a 350), it would be best to use a 700R4. BUT, a 200R4 will allow you to keep your stock drive shaft, and a 700R4 will need a new or modified shaft as that trans is longer. I don't think you can get a lock-up torque converter for $100.00, at least not a very good one. IF it were me, building the direction you seem to be going (a cruiser, not a bruiser) I'd go with a TH350, and it'll be the right length also as long as it has the 6 inch extension housing (TH350 trans come in 3 different lengths). NOW, don't forget that these overdrive automatics require some added electrical wiring to make them function correctly, while a TH350 won't. I'd watch CraigsList.Org in your area for a good deal on a rebuilt TH350 from a private party. You could also go with the TH350 lockup model; it'd be somewhere between a regular TH350 and an overdrive trans. ALL the tri-five/55-57 Chevrolet vendors have whatever you'll need to do any of these conversions.
56 chev trans?
Thanks again for the info J. Stocker. When you say a TH350 lockup is between a th350 and an overdrive trans. such as a 2004r what would that be? Sad to say I am not sure what lockup does. I have heard that a th350 is a 2 speed and the others are 3 speed. Does the th350 get very low mileage compared to the overdrive trans? I would like to make this conversion as simple and inexpensive as I can but not wind up with a
10 mpg car. Again thanks for the replies |
TH350-C, or lock up TH350's, were GM's sort of first attempt at getting better milage with an auto trans. The converter has a clutch in it internally that "locks up" so there is essentially no slippage with the converter in lock up mode. That's what I meant by somewhere between a TH350 and an actual overdrive auto trans. IF your 56 has a stock rear end, and it was always an auto trans car, then the rear end ratio is 3.55:1. With only a 283, if you stick an overdrive in the car, the gears you have, it won't make for the "best" combo. You said originally, "cruising and around town"; you probably don't really need an overdrive trans. TH350 would be a lot cheaper than an overdrive, easier to install, and more than you need; a TH350-C would be one step above that, but before an overdrive. My 56 Sedan Delivery is a Borg Warner Super T-10 car, my 57 Sedan Delivery (former O/SA Junior Stock Class Drag Car) currently has a cast iron Powerglide in it (had been raced originally with an old 4-speed Hydro). It will probably get one of my own built aluminum Powerglides, or a TH350. It is a 220 HP 283 powered car. I personally don't have any experience with overdrive automatic transmissions, other than my 90 Mustang LX 5.0, which I just sold last week. I think I'll keep things that way. Powerglides, are 2-speeds, TH350's are 3-speeds, 200R4 is a "4-speed" with 4th being the overdrive, 700R4 is also a "4-speed" with 4th the overdrive.
Good Info Junior Stocker.
For cruising to store & around town the 350/350C should be cheap & easy. As you said Rear gear change would be needed w/283 and a O/D Trans for cruising. Todd |
56 chev. trans.?
Thanks J. Stocker for the info. My 56 has the standard 3 speed on the column and the stock rear end as far as I know. Dont think it was ever an automatic, so as I understand your info, when I change to a th350 I do not need to change rear end gears? Also, is there an electrical kit I need to install for the th350c lockup trans. and, the mild driving I intend to do around town would I benifit by the th350c ? I like the idea of better fuel mileage, but wonder what the cost difference between the two trans.
Thanks |
If you have ever replaced a turbo 350 with a 200R4 or 700R4 you will probably never want a Turbo 350 again for several reasons the overdrive transmissions have a lower first gear ratio that will get you off the line quicker and on the freeway 2-4 more MPG, been there done that! now that I am back in the "Blue Oval" fold I am running an AOD.As far as the crossmember swap it is EZ since you are in AZ you can get the Trans-Dapt universal crossmember at Lopers,you check for level drill 4 holes in frame and bolt it in with grade 8 bolts about 30 minutes work.Get the Lokar TV cable for the new trans as they are EZ to work with.With either overdrive you will want a 1987-92 core as they have all the reliability upgrades.ABC Transmissions on McDowell in Phoenix is good on prices.
Your stick shift 56 will have a 3.70:1 rear end gear ratio. I still say, for your intended use, a TH350 would be the way to go. An overdrive will work fine, but do you really need it? If you do a lot of open road/freeway driving then an overdrive is just the ticket. But for just in town cruising and errands and such, you won 't be using overdrive. True, the overdrives have a lower first gear, that and your rear end gears will make it a bit more responsive. IF it were me, with how your car is currently set up, I would stick a 3-ring Saginaw 4-speed (3.11 first gear) in it.
56 chev. trans. ?
Thanks for the replys. I was leaning towards a lockup th350 I believe you call it. Hey J. stocker you through me a curve ball. What do you mean by a
Saginaw 4 speed 3.11 ? Is that the rear end and if so, 4 speed? Also did you see my post about electric hookup for th350c ? Thanks. Sorry about being so dumb on these issues. |
Saginaw 4-speed; there are several difference ones, each with different gear ratios, and they're fairly cheap (I just gave one away, along with the Saginaw 3-speed overdrive trans I sold to the guy). The "3-ring" only refers to some circumferential markings on the input shaft splines. They come with NO rings, a single ring, 2 rings and 3 rings. The 3-ring came in Monzas and Vegas, and most consider it a light duty trans. BUT, it would be fine for a stock 283 powered, lower geared rear (such as 3.70:1), car that is just driven for enjoyment, and not beatin' on. You're cars already a stick, a Saginaw will both right in, and only need a yoke change and shifter. Besides, when people look in your car, and see the floor shift and 4-speed knob........... they;ll know it's not just another automatic transmissioned, yawn-yawn, nother' one.
You might want to go over to ChevyTalk.Org, the 55-57 forums, or Tri-Five.com. I go by 56sedandelivery on those two sites; a wealth of info is available on either one, although I prefer CT.Org. |
56 chev. trans.?
I guess I must have creeped on the thread it seems to have gone off a little. My reason for changing out my chev. from the current stick shift on the column to an automatic on the floor is because my wife wants to drive the car, but will not because she is a little shiftless. Ha! So I am going to go auto. I believe from the members response a th350 or th350c will be an eaiser change. I dont want to change rear end gears if the stock one will work and not be detrimental to the auto trans. I believe you folks said I would need an elec. kit for a lockup 350c ? And would that be a little better than a non lockup for my mild driving around town? So, what do you think about the 2 trans. for my car and will my rear end gears which I think are 3:70 based on being told the car originaly came that way be alright. Once again thanks for all your help
Just go with a TH350 NON LOCK UP. |
I agree^^^
TH350C can be annoying around town, you'de have the Lockup switched off anyway because of engine lugging. Factory setup 80-86 used a Vacuum switch to control lockup, and you know those years the engine looked like it had a Spider Web of Vac hoses. 1 leak and the Lockup wouldn't work right. Lockup too early and wouldn't unlock when needed.
| T5 Trans Swap 62 3/4 Chev | tab | Transmission - Rearend | 0 | 05-17-2010 11:40 PM |
| Auto Tech vs. Auto Body Career? | mgold | Hotrodders' Lounge | 41 | 01-04-2010 07:36 AM |
| Auto Trans Help Needed | MI2600 | Transmission - Rearend | 7 | 01-06-2006 07:16 AM |
| Changing to an auto from manual in 57 Chev | pikalpha | Transmission - Rearend | 3 | 12-14-2001 05:30 AM |
| Turbo 350 Trans in '63 Chev p/u | Freedo | Transmission - Rearend | 1 | 09-04-2001 07:59 AM |
