Auto. trans. fluid. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2007, 10:17 AM
Auto. trans. fluid.
I kneed some input, opions on trans. fluid. Best,med,worst.
Dextron III / Mercon. "Wal-mart". Advance auto parts,Auto
Zone. "NAPA" Texaco, Mobile etc. I have used "family dollar store" brands. Wal-mart brand $6.98 per gal, Advance auto
$7.98 / gal. Fluid will be used in stock rebuilt th350.
Coments, pro/con
As always hotrodders BB is
Jim Dandy
Old 07-23-2007, 10:47 AM
jakeshoe's Avatar
Jim,
Nothing wrong with Dexron in any brand you can get. I use the Wal-Mart Supertech often.
I also use tractor trans/hydraulic fluid in some cases
Old 07-23-2007, 11:35 AM
call me crazy...Royal Purple synthetic in everything.
At 6.50 a quart, it ain't cheap. But it works
Old 07-23-2007, 08:58 PM
I've had no problems with the cheap Dexron myself. I started using the Walmart stuff when I started working there in 1994, and since I've been working at Fred's for a few years, I now use theirs. I believe Fred's is made by Warren Oil Co., the same company who makes Coastal products. Wouldn't surprise me if they make a lot of the store-brand stuff.
Old 07-23-2007, 09:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I shop price for the type of fluid I need.
Dexron III ( or current upgrade) , I get from wally world.... I usually add a bottle of red Lubgard
Old 07-24-2007, 05:18 AM
auto trans fluid
You don't often see lubeguard mentioned on this site, but that is some good stuff.
I have seen it cure a chrysler mini van, 670 trans converter chatter after driving the van for only a few minutes!
Old 07-24-2007, 06:13 AM
Trans fluid @ th350
Thanks: Brisco,Crosby,Jimfulco,Frizwell@Jakeshoe. I didn't
think too many co's made trans fluid. Anyway 1 more quik
question. How many steel balls goes in a th350 case? When I tore mine down (disassembled) I didn't find but 2. And they
were in the the rear most two slots .Coments
As always Hotrodders BB
Jim Dandy
why is my 400 trans shooting the fluid back through the filler tube 403pontiac Transmission - Rearend 5 10-31-2006 09:39 PM
Draining/replacing Trans Fluid Th-350 leejoy Transmission - Rearend 3 03-23-2006 08:59 AM
pontiac th350 M31 auto trans poncho_paul Transmission - Rearend 2 01-13-2005 06:48 AM
Running th-350 w/o trans fluid? good/bad? MuscleBlock81 Transmission - Rearend 6 10-10-2004 06:33 PM
B;owing trans fluid out the fill pipe Sandman Transmission - Rearend 5 06-05-2002 08:29 PM
