auto trans loss ratio of hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 04:17 PM
can anyone tell me what ratio loss of horse power you can expect when using a auto trans vs manual. and would one trans be better or worse then another, set up for drag racing.
Old 04-25-2012, 12:01 AM
I'd think that it would be a plus to race with autos
hi,
I'd think that it would be a plus to race with autos for then you wouldn't lose the time to shiift and lose HP when doing the shifting.
In an automatic transmission, each gear possesses a device that, under specific rpm and engine vaccuum pressure, will change the gear. In a manual transmission, you are that device. Also, manual transmissions are geared differently, to make up for operator error when shifting. The differences are gears that are easier for the engine to turn, due to circumference of the gear. A higher gear robs horsepower.
Last edited by Crosley; 04-25-2012 at 06:53 AM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 04-29-2012, 09:28 AM
Autos have the advantage of high stall torque converters for take-off, and consistent shifting. In a manual you have to depend on the clutch and the coordination with your arm moving the shifter. A manual has less power loss, but all it takes is one bad shift to wipe out any advantage.
You also need to consider what type of race you plan to run. In bracket races you need to be very consistent to win, and that will be harder with a manual.
Bruce
Auto Trans for '34 Plymouth rough_idle Transmission - Rearend 1 08-07-2008 11:36 AM
Trans Ratio juiced66malibu Transmission - Rearend 1 09-24-2005 11:11 AM
power loss from higher ratio rocker? KNanthrup Engine 5 08-26-2005 09:20 AM
Auto Trans Install tay Engine 3 06-13-2005 04:39 PM
auto trans to manual Jim Vines Transmission - Rearend 4 02-18-2003 10:57 PM
