Auto trans swap into 79 GMC 4WD?
Got a 79 GMC 4WD. Currently it has a manual trans with a NP-205 transfer case, i know this because of other info and pics i got off this site. What I had in mind was an automatic trans swap. Which would be a better choice TH 350 or 400? Clearly I need a trans with the correct tail piece as it bolts directly to the 205. Will any 350-400 4WD 'bolt up' ? I'm not sure how many configurations of this particular trans there are that mate to a NP 205. Would this be considered a relatively straightforward swap? Any info would be greatly appreciated, Thanks!
welcome to Hotrodders.com
I edited the thread title to provide the members here an idea of what your question is about rather than simply "Auto?"
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Thanks, kinda new here
Yeah I considered a 'donor' truck was hoping for a relatively easy swap, think you're right on the manual trans spline count also
I tried to post pictures of the adapter that you would need .it is a factory adapter check on eBay that's were I got mine . Then you can swap out the input gear on your 205 to a 27 splin .the th350 and adapter is 25 inch long . Plus 1 3/4 tail shaft . Hope this helps drive shafts should be ok but you'll have to measure and make sure
yeah 2.73 gears and 31x10.50 tires. Looks like Advance Adapters has what I need for the conversion. Thanks very much louis165, I appreciate it!
| which auto trans for 56 chev? | db flyer | Transmission - Rearend | 27 | 10-27-2010 05:01 PM |
| Auto trans swap on a corvette | Pupsvette76 | Transmission - Rearend | 6 | 12-13-2009 04:14 PM |
| questions for a auto to manual trans swap | johnnyt5646 | Transmission - Rearend | 0 | 02-05-2009 01:52 PM |
| 1993 Silverado K1500 auto to manual trans swap.. | FinishLine | Transmission - Rearend | 1 | 01-11-2009 08:42 PM |
| swap 3 on the tree for auto trans. | dragon wagon | Transmission - Rearend | 3 | 03-06-2004 02:38 PM |
