Auto trans wont shift when cold - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 10:13 PM
Car is a 97 mercury sable. When cold, like first start of the day, it will drive in first gear until you build up a little speed, then it acts like its shifted into neutral and only free revs until you slow back down. After a minute or two of this the transmission acts normal. Youd never know there was anything wrong with it.
It was taken to a shop, similar to a jiffy lube, and they did a fluid change but I am unsure if they changed the filter or not.
What do you guys think?
Old 02-03-2012, 06:14 AM
tnsmith10's Avatar
when will it rain???
more than likely theres a problem with the intermediate clutch drum. its a common problem with those transmissions.
Old 02-03-2012, 11:00 AM
Hmm, sounds like its time for a rebuild?
I've been driving the car since it acts fine if you let it warm up, or drive a half mile or so real slow to let it warm up. Is there a chance its going to completely quit real soon and leave me stranded?
Old 02-03-2012, 01:12 PM
tnsmith10's Avatar
i wouldnt think so but, i dont know anything else about the car or trans to say so.
had a customer when i was in NC that had the same problem and when we got inside of the trans, it had a cut lip seal for the apply piston. not saying thats the case here, as anything is possible.
Old 02-04-2012, 11:45 AM
I discovered this morning that the car has no 2nd gear when its cold. If i move the shifter into 1st gear it will not slip at all. I can drive around in 1st gear at about 20-25 mph until the trans is warm and then pull it back into drive and it will shift like it should. I do think it goes into overdrive way too soon tho and it sorta lugs the engine.
Old 02-07-2012, 04:45 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
9 times out of ten, shifting problems when cold are due the the seals being old and hard , after they warm up they become soft and flexible again, and start sealing, its time for a rebuild.
Old 02-07-2012, 04:54 PM
Here is another thought.
Try adding about a cup of ATF to the transmission. Transmission fluid like most things expands a bit when hot. If a typical transmission has two to three gallons of fluid, the volume may change enough just warming it up to make the transmission work normally again. Also warm fluid runs back down into the pan a little faster.
T-350 trans wont shift out of 1st stanjr41 Transmission - Rearend 4 12-31-2011 10:39 AM
350 turbo trans wont shift targettracer Transmission - Rearend 3 07-06-2011 11:49 AM
my 350 trans wont shift out of 1st gear 86montecarlo Transmission - Rearend 2 04-25-2011 07:26 PM
700r4 trans that wont shift to dr or od emyers Transmission - Rearend 3 03-19-2011 04:51 PM
T-350 trans, it wont shift jettajo42 Transmission - Rearend 1 06-15-2008 11:05 PM
