Auto Transmission Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 07:25 AM
Hi everyone
Need some HELP.
Have a 1985 chev c10 pu ,chopped,pro streeted 454 tri power ,TH 350 trans.
Lately as it sits in garage between car shows trans fluid leaks out trans yoke onto front universal joint. I took yoke off and JB welded the cap thats pressed into yoke,leak stopped for 1 week,now leaking again
I was a GM tech for 20 years but never did alot of AT,4 speeds and ring and pinions was my good points
Old 05-01-2011, 08:44 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Welcome to HR.com, Rat Ron.
Glad to have you here. Someone is going to give you a solution, I'm sure.
I always thought my th350 was just marking it's territory.
I was never able to make it stop till I installed a 200r4 trans.
Good luck.
454 RATTLER
Old 05-01-2011, 03:56 PM
SSedan64's Avatar
Could try Tapping the vent hole & installing a small Set Screw. Would have to remove the Yoke from Driveshaft again. JB probably didn't stick well.
Is the Rear Seal & Bushing in good shape?
Old 05-02-2011, 06:42 AM
TH 350 Trans leak
Thank you for getting back to me
No leak from rear trans seal. I took yoke back off and JB weld is ok.
Looks like oil coming out of vent hole in yoke,wich I can plugg.QUESTION that bothers me,is I've owned truck for 25 years and it never leaked before,why now coming out yoke. I didnt think that much trans fluid could be in tailshaft housing,nothing back there but speedo gear.
Old 05-02-2011, 10:43 AM
Mr.NutCase's Avatar
Check extension housing bushings...
Replacing just the seal is wrong thing to do.
Fix the problem,not the symptom..
Old 05-02-2011, 11:56 AM
Trans leak
Thanke for reply Mr NUTCASE
Seal NOT leaking,trans fluid coming out front driveshaft YOKE VENT HOLE
Old 05-03-2011, 09:20 AM
SSedan64's Avatar
May be worth checking the Trans Case Vent Tube>> http://media.photobucket.com/image/r...TH350-vent.jpg Dirt Dabbers can plug them up.
When the Engine's running the fluid level is even with Pan mounting surface & pressure can escape out the Dipstick tube. More so if the fluid level is slightly low.
When the vehicle sets the fluid in the TC/TorqueConverter drains back into the Pan raising the level much higher and pressure buildup may be pushing it out the Yoke vent. Maybe, maybe not. Easy to check anyway.
Todd
Old 05-05-2011, 11:32 AM
Trans leak
Thanks for info SSEDAN64
I know coverter drains back and level goes up. I pulled yoke off JB weld was ok so I drilled and tapped hole,installed screw,and JB over it.I put back in truck ,but raining here so wont take for a ride yet.
I ckecked vent,it was OK.
Let you know how I make out
Old 05-25-2012, 04:20 PM
There's an oring that goes in the yoke it probably finally broke apart after all those years thus now its leaking get from the dealership or go to autozone or advanced or whatever for just a plain oring kit with a bunch
Auto transmission leak at speedometer cable HotRodMan Transmission - Rearend 3 04-11-2011 07:07 PM
Oil leak 350 Transmission Richard O Transmission - Rearend 1 04-05-2010 02:07 AM
transmission leak: paulie64 Transmission - Rearend 5 10-07-2008 03:39 PM
Transmission Leak EazyDuzIt102 Transmission - Rearend 5 08-13-2006 07:18 PM
what transmission goes on a 302 auto??/ acself03 Transmission - Rearend 3 04-09-2006 11:46 PM
