autolite 65 or 144? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2008, 05:26 PM
autolite 65 or 144?
hi,
I currently have autolite 65's in my 454 right now and when i just pulled them they were black. I was wondering what the difference is between the 65's and the 144's? Are the 144s a hotter burning plug? I have never used another plug besides the 65's but i obvesly need to change.
thanx
david
Old 03-15-2008, 07:06 PM
engineczar's Avatar
Just the opposite as far as the heat range on an Autolite. A 5 is hotter than a 4.
The bigger problem is that these are two entirely different size plugs. The 65 has a hex size of 13/16, a gasket seat, and a body length (reach) of 3/4. The 144 is a 5/8 hex, taper seat, and a reach of .460
Do you know what head casting you're using on your 454? If not that what year.
BSE Racing Engines
Old 03-15-2008, 11:14 PM
they are the eldelbrock rpm performer rectangle port heads.
thanx,
david
Old 03-17-2008, 06:46 AM
engineczar's Avatar
The 65 is the right type. An Autolite 3924 is closer to what Edelbrock recommends. The Edelbrock head uses a 3/4 reach gasketed plug with 13/16 hex.
There are quite a few numbers that have that configuration.
If the plugs are black or sooty it sounds like it's running a tad rich or you don't have enough initial timing in it to keep it running clean.
BSE Racing Engines
Old 03-17-2008, 10:03 AM
thank you for the info. I just looked at the plug again and its acually a autolite 64. I tried to see the differance between a 64 and 65 and I dont see any different specs at all. Is there any?
thanx
david
Old 03-17-2008, 10:43 AM
engineczar's Avatar
The 64 is one step colder than the 65. Other than that no difference
BSE Racing Engines
Old 03-17-2008, 10:48 AM
thanx. i think ill try the 65's
Any tips to ID a real L-79 65 Chevelle?? F&J General Rodding Tech 0 09-15-2007 07:42 PM
It's a sickness, Bought another 65 1Fast65Elky Hotrodders' Lounge 9 04-03-2007 04:59 PM
65 sport deluxe - kelico kelico Introduce Yourself 3 10-09-2006 04:24 PM
Newbie-- 65 Riviera, 65 Corvette, 65 burb owner fatrink Introduce Yourself 1 07-16-2006 07:18 PM
74 to 65 rear end gear swap? 65_Chevy Transmission - Rearend 4 06-26-2005 01:29 AM
