Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - autoloc bear claws
Old 07-06-2012, 11:00 AM
lebrush lebrush is offline
autoloc bear claws
I have a '48 Ford tudor full custom with existing shaved handles and solenoids door openers installed---I notice the stock door latch releases on that model year don't release enough to pull the door open-when the door is open the solenoid works fine pulling the latch inward--but when the door is closed--it seems too tight to pull back the latch--do I have to use a Bear Claw latch set(which I already have a small set in box) or can I modify the stock latches to work better. Has any one out there ever installed Bear claws on a '46-'48 Ford or modified the stock latches to work. thanks, Vince
