autoloc bear claws - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2012, 11:00 AM
autoloc bear claws
I have a '48 Ford tudor full custom with existing shaved handles and solenoids door openers installed---I notice the stock door latch releases on that model year don't release enough to pull the door open-when the door is open the solenoid works fine pulling the latch inward--but when the door is closed--it seems too tight to pull back the latch--do I have to use a Bear Claw latch set(which I already have a small set in box) or can I modify the stock latches to work better. Has any one out there ever installed Bear claws on a '46-'48 Ford or modified the stock latches to work. thanks, Vince
Old 07-12-2012, 07:04 PM
Done both on the 48 model the stock ones can be modified to work however the bear claws work so much better and are actually more secure when closed the stock latch seems to have a looser fit even after modification
Old 02-06-2013, 10:04 AM
416Ford's Avatar
I'm having a similar problem with mine lebrush, how much ft/lb solenoid are you using? I do not have solenoids yet for mine and I want to buy them. Worried that they will not pull hard enough to open the door.
Has anyone installed bear claws on a car that already been painted? I think that is something that would be a question for both of us.
Not trying to steal your post lebrush, just get the answer to the question you asked.
Old 02-06-2013, 06:21 PM
Bear Claws
As it turns out I bought the bear claws, but never installed them, I sold the car. Thanks
ince
Stock 36 ford handles and Bear Claws? Metal Twister Body - Exterior 8 03-21-2008 02:02 AM
Stock Latches-Can I use them or should I convert to bear claws? trifivefan Body - Exterior 5 04-17-2006 10:28 PM
Bear claws in a Model A luckyscustomcreation Body - Exterior 1 10-21-2005 01:22 PM
Bear claws with outside handles al37ford Body - Exterior 1 10-19-2005 10:45 PM
Bear Claws on a 41 (thru 48?) Chevy question redsdad Body - Exterior 3 10-17-2005 08:45 PM
