-   -   Automatic trans for 235? (http://www.hotrodders.com/forum/automatic-trans-235-a-48141.html)
Slickriffs 09-20-2004 01:09 PM
Anyone familiar with what automatics are readily compatible with a truck with a 235 engine? I think a 4 speed automatic was an original trans option.
Thanks,
Keith
stu 09-20-2004 01:24 PM
There are many that will fit the bolt pattern.
PowerGlide
TH350
TH400
700r4
200 4R
willys36@aol.com 09-20-2004 01:55 PM
I just installed a 200R4 on my 253 using a Langdon's StoveBolt Engine Co. adaptor. Haven't started the engien yet but the tranny went on w/o problems.
Slickriffs 09-20-2004 02:19 PM
Thanks Stu..Didn't realize there was so much compatible with the old 235.
Willy's...Crank that sucker up!..I want a progress report on all your additions. I think I'm goin with the Toyota power steering also. NO-Limit has a similar kit. Mounts near original position instead of on top of frame rail. Thanks for the info about stove-bolt.
Keith
willys36@aol.com 09-20-2004 02:53 PM
That NoLimit kit is for the '55-'59 frame which came from the factory w/ thru-the-frame steering. The top-of-the-frame position I put my Toyota steering gear is almost exactly where the stock unit went on the pre-'55 Advance Design frame.
