Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - automatic transmission cooler question
Old 06-04-2011, 06:59 PM
Irelands child's Avatar
Irelands child Irelands child is offline
Why not?? There are many - from the usual finned and in many sizes. There are also versions with external fans which are temp. controlled. Then there are the extruded aluminum versions from 12 - 24 or more inches. That last one is what I'm running and so far haven't seen the tranny get more than 160F in traffic on a very warm day
This is a 24" dual pass, mounted outside of the right frame rail and under the running board splash shield and mostly in the air stream:
Dave W
Irelands child
