Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - automatic transmission cooler question
Old 06-05-2011, 07:08 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Originally Posted by sherman8r
dang it, I ordered a derale electra-cool fluid cooler after the first couple posts. i guess I'll order a trans temp gauge and see how things work out. I'll keep you updated on how it works.
If you have an aftermarket water temp gauge, all you need is a double pole switch, some wire and a $10 temp sender mounted in the pan - the gauge doesn't care whether it's water or oil.
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
Bonneville462 (03-12-2013)
