Automatic Transmission Fluid Type A - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 04:07 PM
I have recently brought a car out of long term storage. The automatic transmission calls for ATF Type A. It is a 2-speed Oldsmobile transmission, maybe it is called Jet-a-way instead of just Hydro-matic. My local NAPA dealer says that they stopped making the fluid because of a whale oil ban. The auto-oil industry then changed the engineering and requirements of automatic transmissions, so it simply is not longer made.
Is ATF Type F (now FA) better than Dextron I,II,III, Mer-con III, or V ? Is there a particular/specific ATF additive that will bring a present fluid up to the heat resistance and lubricity levels required?
Old 11-20-2005, 08:01 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Information from Google.
http://oil-store.com/OilStore/ATF%20Nutshell.htm
From Pennzoil = If I understand this correctly, Type A is superceded by the Mercon series, the newest being Mercon V.
On this one if you scroll down page one, it says that A is replaced by Mercon
http://www.shell.ca/code/products/co...eader/6-01.pdf
Old 11-21-2005, 02:31 AM
aka Duke of URL
Origional TYPE A and TYPE A SUFFIX A were long ago replaced by DEXRON III/MERCON. MERCON V is to be used exclusively on FORD automatics specifically calling for it.
Convert manual transmission to automatic Jim69Mustang Transmission - Rearend 0 07-11-2004 01:51 PM
Storing unused transmission fluid 406chevelle Transmission - Rearend 4 07-03-2004 11:36 PM
How Much Transmission Fluid? EazyDuzIt102 Transmission - Rearend 8 01-12-2004 03:28 AM
fluid capacity of a ford C6 Transmission Dubz Transmission - Rearend 4 12-13-2003 11:10 AM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 06:22 AM
