automatic transmission help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2005, 08:14 PM
Hi,
I currently have an automatic transmission that seems to have a problem with it. When i'm on a NOT so steep hill i push my foot hard down on the accelerator and it will stay in first gear for about 5 seconds before changing to second gear. Also sometimes when i push the accelerator when driving on a flat road the tranmission doesn't respond for about 2 seconds. What is wrong with my auto transmission and how long would this take to fix??? 1 hour?
Previously when i bought the car it was missing a gear so the guy installed one for me but now i've got this new problem.
Old 03-17-2005, 08:21 PM
Mr Ed's Avatar
what type of car/trans?
Old 03-17-2005, 08:29 PM
transmission
its a nissan pulsar and its an automatic 4 gear transmission with over drive
Old 03-18-2005, 03:02 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
From what I gathered from the description, it is operating normally.
I have seen a few things that make me actually wonder a few things here though.
I am wondering your age, and if you have driven an automatic transmission equipped car before.
I noticed a difference in language useage and checked out your IP address, you are from New Zealand.
From what little I know about New Zealand, I cannot help but put this tidbit of information in here for others to be aware of, cultural differences make the meanings of the same word end up being very different.
If there is a problem with the transmission, you can expect anywhere from minutes at the least, to weeks at the most, to wait for replacement parts if they are required to fix the problem you describe.
Can you tell us what speeds the transmission shifts up at, with the accelerator held at a steady midway point, and if it has a tachometer, the RPM's it shifts at also?
Old 03-18-2005, 03:51 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
pauses in tranny
It can be as simple as a clogged filter. The fluid cannot get to the proper places quick enough.
Old 03-18-2005, 06:33 PM
adtkart@aol.com
Actually... with an automatic transmission, there should never be anything that would plug a filter. That being said, a plugged filter is not a simple matter.
Vehicles with automatic transmissions will shift based on how much pressure is being exerted on the gas pedal. A vehicle with alot of power, like a V-8 Ford, will shift earlier on a slight hill, than something like a Nissan with a small 4 Cyl., accelerating at the same speed. That being simply because the engine is not being stressed as much. Like M&M said, you should check the speeds that it shifts at under normal/moderate acceleration on a relatively level road.
fastest muscle pre 1970 81elcamino Hotrodders' Lounge 86 01-19-2009 05:53 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
Convert manual transmission to automatic Jim69Mustang Transmission - Rearend 0 07-11-2004 02:51 PM
"49" Ford Business Coupe Custom Transmission Swap standard to late model Automatic Rockin Rick Transmission - Rearend 4 10-14-2003 02:40 PM
automatic transmission problem? Rod MI Transmission - Rearend 2 09-24-2002 04:34 PM
