automatic transmission problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2002, 10:12 AM
Post automatic transmission problem?
Hi Iím looking for a general answer to a automatic transmission problem. I have a pick up that has been sitting for about 5+ years and the last time I started my truck the transmission would engage into drive slowly and would just lung forward when given gas wouldnít move more then a inch how big of a problem could this be thanks
Old 09-24-2002, 03:32 PM
dklong's Avatar
Post
check your fluid level and condition , low fluid level will cause slippage ,if low top up fluid and try again. or you may have an internal trans problem, such as seals dried out and harden, due to age and not in use.
Old 09-24-2002, 03:34 PM
dklong's Avatar
Post
due to bad seals the only cure is a trans over haul.
