autometer gauge pig tailing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2010, 09:01 AM
so ya wiring up my electric autometer gauges.
how does this sound. with painless 12 harness
took red/white power wire and pig tailed all the gauges together.
then made a ground wire and pig tailed all the grounds together
then ran the ground gauge lights to the little posts on the guages(there part of the ground that the other grounds are at. then took brown wire and pig tailed all the pos gauge lights together. Sound right
Also can I just carry on and wire the electric speedo to the same pig tails I have been doing.
instructions say the speedo pos 12volts wire must be fused and red wire from speed sender joins into the same wire.. getting tired and not even sure if this makes sence any more. Will edit in morning.
trans is 700r4 with 3 wires coming out of the sender.
Autometer gauge ? chewyscool Engine 2 01-02-2010 05:22 PM
Autometer trans temp gauge, can I take apart? bubbahotep Electrical 5 04-07-2009 07:40 AM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
Possible for autometer temp gauge to be bad? fouroheight68 Engine 8 02-21-2005 11:20 AM
IDIOT needs help on first autometer gauge install, hurry or i will blow an eye out dontknownuttinboutnuttin Electrical 12 12-02-2002 04:24 PM
