autometer guages? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 04:29 AM
autometer guages?
Im just curious, is there any way to install aftermarket guages, but in parallel? So that the autometer guage and the stock guage both work? I have guages in my trans am, but the stock ones just sit there, I think it would be so much nicer if they both worked. Its small, but I would love it! I didnt install the guages so im not sure, thanks!
Old 10-26-2010, 05:00 AM
EOD Guy's Avatar
I have never tried it but it should work, might have a reduction in accuracy due to the dual feeds. You could hook up a relay bank to switch from stock to the new with a flip of a switch. I do have a backup camera on my truck that feeds the rearview mirror monitor and the in dash monitor at the same time and that seems to work pretty well
Old 10-26-2010, 08:05 AM
302 Z28's Avatar
Will work fine if hooked up parallel.
Vince
Old 10-26-2010, 09:03 AM
001mustang's Avatar
I would check resistance to ground from sensor w/ and w/o gauges connected.
Check in standby and during operation.
If minimal change in resistance then gauges should be accurate.
Old 10-26-2010, 09:12 AM
TroyBoy's Avatar
Psychomotors
Use 2 senders,thats what I did with my truck till I could get the new electric gauges installed.
Old 10-26-2010, 09:34 AM
001mustang's Avatar
BTW.
The gauge I installed in truck came w/ a dual post sender.
One post for gauge, second post for idiot light.
Old 10-26-2010, 03:02 PM
35terraplane's Avatar
autometer gauges
They would work, but I don't think they would be accurate, as most are using a certain resistance. if you had two senders the stock one and the autometer but there is only room for one with the gas gauge. the others, oil, temp, and volts you could put two senders in a chev. If they were all electric gauges i think they would work. You could make an amp gauge work but if it were me I would not want to put that many breaks in that wire. I just re read your post so you do have a Gm. and volt meter two senders, but SOL i think on fuel gauge.
35terraplane
Old 10-26-2010, 04:15 PM
EOD Guy's Avatar
This is amazing
Old 10-26-2010, 06:00 PM
TroyBoy's Avatar
Psychomotors
Originally Posted by EOD Guy
This is amazing
Whats amazing?
Old 10-26-2010, 06:09 PM
Vince
Thanks. I was wondering the same thing. I did not know how to hook it up, but this is very helpful. I would have not thought to hook it up this way. Thanks for the tip.
Old 10-26-2010, 08:28 PM
EOD Guy's Avatar
The way some advice is given.... or repeated...lol seems like people are in such a hurry to post something they don't bother to read the previous posts and offer almost the exact same advice i'm just say'in
Old 10-27-2010, 09:24 AM
TroyBoy's Avatar
Psychomotors
You will see that alot. Stick around, you aint seen nothin yet
Old 10-27-2010, 10:00 AM
001mustang's Avatar
I don't mind hearing 2nd and 3rd and....opinions. They often don't coincide.
I get lazy when posts are so long,wordy and off message; like this one.
Purple wire, electrical guages ( Cyberdyne ) KeithB123 Electrical 2 04-21-2007 11:48 PM
Anyone taken apart Autometer Guages? JhnBrackett Electrical 4 06-16-2005 09:33 AM
Backlit guages please!!! nitsud08 Interior 9 05-10-2005 07:58 PM
Autometer Guages scott011422 Electrical 1 09-12-2003 03:11 PM
digital guages for 65 elkie ekcaminoron Electrical 3 05-07-2003 07:28 AM
