Autometer mechanical temp gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 08:58 AM
Last journal entry: Accessories can drive you mad
Changed headers. Old ones were wrapped. New ones are painted. I have the sender with the capillary tube running under the #8 tube with about and inch of air gap. Rear of passenger cylinder head. Now when the cars idles the temp climbs from 180-210 in about 5 minutes. I am thinking heat soak. It never did this before. When I drive it drops back down to 180. When I turn the car off it pegs the gauge at 280! Anyone else have this issue with the mechanical gauge?
Old 04-04-2013, 10:21 AM
Haven't configured one as you describe, most common SBC Gen I set up I use is to come off the near center tap on the heads, passing above the header tubes.
I do find that that at idle the otherwise "normal" running temp will slowly climb this is just a function of air flow reduction across the radiator core without road speed to ram air flow through the core.
At shut down the temp will climb, but 280 seems high, my installtions usually see a climb to 220-230 which comes right down when the engine is fired up while still hot. Of course this is an event you don't see with an electric gauge as it and the electrical system is shut off with the engine.
Bogie
Old 04-05-2013, 05:45 AM
Last journal entry: 50 Ply wagon
The brass rod at the end of the capillary is the only part that transmits temp. If you have the sending unit in the head, that's why you are seeing such high temps when you shut off the car. The coolant surrounding the sender is now stopped and since the heads produce more heat, it is transferred to the sender.
The sender can be located where you have it but it is usually in the manifold near the top hose outlet.
Mechanical Water Temp gauge Joer5000 Engine 1 06-10-2012 10:21 PM
temp. gauge....mechanical or electric? Hwyhogg Hotrodding Basics 8 08-19-2011 10:12 PM
Mechanical screw on temp gauge fierosum General Rodding Tech 2 06-07-2009 07:47 AM
Autometer trans temp gauge, can I take apart? bubbahotep Electrical 5 04-07-2009 07:40 AM
Possible for autometer temp gauge to be bad? fouroheight68 Engine 8 02-21-2005 11:20 AM
