Autometer speedo calibration? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2012, 03:50 PM
Localboy808's Avatar
I have an Autometer Phantom mechanical speedo that reads way too high. Maybe 20mph too fast. It's cable is hooked up to a TH350. I'm running 3.73 gears in the rear end and have 15" rims. Eventually I'm looking to change the rims to some 17" Torque Thrust rims. What is the easiest way to get this guage to read correctly?
Thanks, Scott
Old 05-09-2012, 03:56 PM
LATECH's Avatar
Change the speedo gear in the trans. You may be able to correct it by changing only the driven gear.
http.www.transmissioncenter.net/
Look here. They have a speedo calculator section in there and also tells what gears to use. And they also sell them.
Fact is stranger than Fiction
Old 05-09-2012, 04:09 PM
Thanks man! Never done this before. I'll check out that link. Where are the gears? Do you have to drop the pan to get to it? Is it a big job?
Old 05-09-2012, 05:11 PM
LATECH's Avatar
Just need to yank out the speedo "bullit" to change the driven gear. To change the drive gear , pull the drive shaft, then the tailshaft housing from the trans(4 bolts) and the gear will be right there.Just depress the clip and slide it off. Piece of cake.
Old 05-09-2012, 05:25 PM
That sounds easy enough. If I only had a lift! thanks for the info and thanks for your contribution here!
Scott
Old 05-09-2012, 06:48 PM
LATECH's Avatar
You can use car ramps. Just run the cars rear wheels up on the ramps to gain easy access to the drive shaft. Leave the car in neutral (makes it easy to reinstall the drive shaft) AND BE CERTAIN TO BLOCK THE FRONT WHEELS so the car doesnt roll over you, please be safe , we like to keep ALL our members. Best of luck Scott.
89 GMC Speedo Calibration Alaska_Man Electrical 1 11-30-2010 02:57 AM
autometer speedo questions dusterbd Electrical 0 03-07-2009 09:09 PM
4L60E speedo calibration 93 GMC UR50SLO Transmission - Rearend 1 04-13-2007 07:50 PM
speedo calibration problem solvers Introduce Yourself 1 08-10-2006 07:31 PM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 07:46 PM
