Autometer trans temp gauge, can I take apart? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2009, 03:59 PM
bubbahotep's Avatar
I have a mechanical trans temp gauge thats been in the car for about 15+ years. It has the 1/4" thick sealed tubing which goes from the gauge to a little aluminum block that you run the trans fluid through so it can read the temperature. Normally, you disconnect at the aluminum block thing and then run your tubing through the dash, around the engine compartment etc. and reconnect at the aluminum.
My problem is, I want to move the gauge now. Theres a bolt on the back of the gauge that comes off and I have access to the metal tubing that goes into the meter. The tubing is glued (or so it appears) into the rear of the meter and that bolt doesnt hold a damn thing. The bolt hole itself is actually twice as large as the tubing and cant possibly hold anything together.
Question: is it possible to remove the tubing from the rear of the gauge and then reconnect after I move the gauge or is that all 1 sealed system???
Old 04-02-2009, 09:06 AM
Last journal entry: 50 Ply wagon
A mechanical trans temp gauge is just like an mechanical oil temp. The line or hose can be taken off and re-attached. But I would contact Autometer to make sure........Autometer.com
Old 04-02-2009, 06:11 PM
ericnova72's Avatar
More for Less Racer
A mechanical temp guage is not like a mechanical oil guage, you cannot disconnect it at the guage without ruining it. There is a special fluid in the tubing of a mechanical temp guage, that is why you have to be careful with the tube and sender bulb.
Old 04-06-2009, 10:35 PM
Very very true, I think it's ether in there. Also, you can't replace the sender once you hack it off, once it's gone it's gone as the fluid will come gushing out. Damn previous owners...
Old 04-06-2009, 11:34 PM
ericnova72's Avatar
More for Less Racer
I also believe it is ether, but I'm not positive, smells like it tho...
Old 04-07-2009, 07:40 AM
302 Z28's Avatar
Alcohol
Vince
Installing temp gauge probe 390 Ford Engine Chief-e9 Engine 3 03-10-2009 01:05 PM
Diff temp gauge? Jag Daddy Transmission - Rearend 3 05-25-2003 05:38 PM
Diff temp gauge for Jag rear end Jag Daddy Transmission - Rearend 0 05-09-2003 05:36 PM
1950 Buick temp gauge in engine stuck! reluctant_paladin Engine 1 04-10-2003 08:49 AM
IDIOT needs help on first autometer gauge install, hurry or i will blow an eye out dontknownuttinboutnuttin Electrical 12 12-02-2002 04:24 PM
