autoweld gas flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 07:27 PM
autoweld gas flow
Does any one know how long a small bottle of autoweld should last ?Spot welded two cab corners and the tanks mt.
Old 01-15-2006, 07:50 PM
What size tank? Sounds like maybe the solenoid is stuck or has a bit of junk in it holding it open allowing the gas to flow continuously. Does the gas shut off when you release the trigger? Is it leaking around the fitting on the tank? You no doubt have a leak somewhere.
Old 01-15-2006, 08:22 PM
autoweld gas flow
it's roughly a3 ft tank. and you can hear the gas when the trigger is pulled . i also turn it off when i power off .maybe they gave me a near mt tank.i have a 2 dial gauge which didn't seem to move off 0.
Old 01-15-2006, 10:39 PM
If you are using C/25(CO2/Argon) you should have over 1800 lbs PSI and straight CO2 should be over 500 lbs so if the high pressure gauge did not or only barely moved then you started with an empty tank. With the C/25 the high pressure gauge will drop as the gas is used and the pressure reading is an indication of how much remains but the CO2 will not start to drop until the tank is nearly empty. It will fall a small amount when you start using it due to temperature drop but with CO2 you cannot tell how much remains in the tank by looking at the pressure on the gauge, unless of course it is at or near zero in which case it is empty.
Help Please? 87 Dodge mini-ram van - stalling if little gas applied jojo99 Engine 3 07-27-2005 06:19 PM
AV gas Chevy Thunder2 Engine 51 03-21-2004 12:26 PM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 05:22 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Sunoco = American gas supplier?? '54-Hunter Hotrodders' Lounge 2 02-26-2003 03:28 PM
