Aviation Form-A-Gasket Sealant for headbolt threads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2008, 06:43 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
Getting ready to put my heads back onto the new 406 shortblock and was wondering about using "Aviation Form-A-Gasket" sealant as a pliable (or should I say "viable"?) solution for headbolt thread sealing. Anyone ever used it for this application? My thinking is that it might produce a bit less drag on the fastener(s) {ARP Bolts} than pipe sealant or black RTV silicone-which are possible options mentioned to me by some other people locally (whom both swear they've used them successfully). I'm just thinking I might get "truer" torque readings-especially on 2nd and 3rd stages of tightening to final torque value. Could I get some feedback on this? (Heads are aluminum-thick deck, and yes I'll be using oil on the usual places). -Thanks,Jim.
Old 06-20-2008, 07:03 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I haven't used aviation for a long time, but I think it gets tacky, I would use what just about everyone
else uses, black silicone, & a can of sealer when you
fill it with coolant.
Rich
Old 06-20-2008, 07:29 PM
I use Permatex Aviation form-a-gasket for sealing head bolts and never had a problem. It will get tacky if left out to semi dry. But I put it on the threads and put the bolts in without time for set up.
gcrmcc
Old 06-20-2008, 07:39 PM
King of my Man-cave.
Not everybody else uses silicone for head bolts and, if fact, it is not recommended for that purpose.
tom
Old 06-20-2008, 08:02 PM
+1 ^^^
I do not like silicon for this reason. Silicone rtv has been found in more places than it doesn't belong than where it does. JMO
Aviation #80019 is some wonderful stuff, as is hylomar, and many other non silicone sealants.
Old 06-20-2008, 08:16 PM
remember the days before silicone? silicone is great on the corners of pan gasket and intake in proper proportions. i get engines all the time just gooped up everywhere. any way do as tom and stroke said.
sam-missle
Old 06-20-2008, 09:09 PM
Thanks for the input guys, I really prefer the idea of the Form-A-Gasket sealant, as I believe that,"as applied",in it's thinner consistency,it MIGHT allow for more accurate torque readings, and I had absolutely no doubts about it's sealing abilities,-just never used it for this application before. I'm also of the belief that it may stay more flexible and affect any possible re-torqueing values less than other products. So... that's what I'm gonna use!-Just wanted to get some opinions on the positive side of that idea first!-THANKS AGAIN.-Jim
Old 06-21-2008, 05:08 AM
v8hed's Avatar
AK427
My 350 had what looks like black RTV on the headbolt threads. It's gonna be fun cleaning-out the bolt holes in the block! For re-assembly, I'll be using Loctite 572 as recommended by a respected engine shop over here. I was going to use ARP thread sealer, but they advised against this unless the block was new (or new-ish). They advised me to go with Loctite 572, as this was a product they'd arrived at after lengthy discussions with Loctite to resolve issues they were having with other sealers. It's pricey ($30+ for a small bottle) but it has a long shelf-life.
Cheers,
Ian.
Old 06-21-2008, 05:48 AM
We use Arp head bolts for our builds and use there thread sealer as recomended and no issues over the years.
Old 06-21-2008, 10:38 AM
IMO
the most important factor is thoroughly cleaning the threaded hole with a brass gun barrel bore brush, and thread chaser if necessary, using spray cleaner, and thoroughly drying with compressed air.
I prefer the ARP sealer
but have used liquid teflon and Aviation Permatex (brown liquid in the bottle with a brush) with success in years past.
Silicone RTV is a no-no most everywhere except intake manifold end seals.
Since silicone was mentioned for pan corners, IMO I prefer one piece rubber pan gaskets.
Old 06-21-2008, 11:49 AM
I was indeed referring to the {Aviation Permatex (brown liquid in the bottle with a brush)} myself when I was making the initial inquiry, and yes I'll be certain to be sure the tapped threads in the block are thoroughly clean and dry. Anyways...Thanks to all for the feedback. I gotta run;Wifey wants the computer back! -Jim
Mr. Gasket Arcuden Engine 12 10-02-2007 04:27 PM
high temp exhaust gasket in sheet form ? lowROLLERchevy Engine 7 01-09-2007 12:03 AM
Gasket Sealant terry65elcamino Engine 7 12-22-2003 10:19 AM
