AVS carb adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2010, 05:55 PM
AVS carb adjustment
Any of you guys got one of these mechanical/vacuum secondary carbs? Been doing some adjustment,tuning, and trying to find a happy place where that door opens without slamming shut almost instantly. Then if I turn the spring one nano less tension it opens to easy totally negating its benefits. With something that hairy I struggle to believe that little spring is going to stay in that magic spot of tension should I happen to find it
Old 04-20-2010, 09:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are you saying the secondary air valve opens, then slams shut, while you're still at WOT?
Old 04-20-2010, 11:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Denny
Sounds like he is trying to make them open while in park, You can't do that.
That's true- if they're opening w/o a load on the engine, they'll open WAY too soon on the road...
Old 05-14-2010, 06:53 PM
Sorry for the late reply. Got onto other things. Yes thats what I'm saying. Breather off,hood off,watching at WOT. Flies open for 1/2 second or so then shut. I keep lightening spring tension but not much difference in results. I'm soon going to crank the thing right open and use it as a straight mechanical 650 CFM
Old 05-14-2010, 08:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Out on the open road, you ain't gonna like the results of doing that, I can assure you.
Tune the secondary opening w/the engine under a load. Safely. No other vehicles/pedestrians, pets.
Trying to tune the secondaries by jazzing the throttle in neutral/park will not be any indication of how it will behave under a load. If it opens up in neutral, it will bog in real world driving, because it will be opening too soon.
Old 05-15-2010, 04:48 AM
[QUOTE=cobalt327]
Trying to tune the secondaries by jazzing the throttle in neutral/park will not be any indication of how it will behave under a loadQUOTE]
exactly.
i,ve always tested on road
Old 05-15-2010, 06:02 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
As cobalt explained, you can not adjust the secondaries in that way and expect it to be drivable (perform like it is designed).
You can not run it as a mechanical 4bbl either, there is no squirter to help with the transfer from idle to part throttle unless you way over compensate with the primary squirter and again the carb is not designed for this and it will not be performing as it could.
Edelbrock performer or edelbrock thunder avs? eric32 Engine 1 09-08-2009 12:25 AM
Carb Recommendation please My68Vette Engine 29 07-03-2009 06:14 PM
Edelbrock Carter Carb. Adjustment shad88 Engine 12 02-10-2009 09:28 AM
Carb adjustment needed? 305Guy84 Engine 5 06-19-2006 12:08 PM
Holley Carb Brass Float Adjustment leejoy Engine 2 04-14-2006 10:02 PM
