awd caravan trans. leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2008, 10:14 PM
Is anyone able to please advise me if there is anything to know in advance of removing the solenoid assembly on my 94 awd overdrive auto transmittion. After changing the oil and filter and cleaning up the area, I realized my leak was from the solenoid and not the pan. I just don't want any surprises by removing it. Is it sealed with the trans. silicon or have a gasket. Thanks in advance for any advice.
Old 02-08-2008, 10:58 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
(Three?) bolts and a gasket, no check balls or springs (Jack in the boxes).
Don't forget to reinstall the insulator (heat shield) no matter how damaged. There may be a thimble screen, now would be a good time to remove and clean it. You should be able to get that gasket at Napa.
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-11-2006 11:24 PM
trans leak Lonestar Transmission - Rearend 11 07-20-2006 09:51 PM
727 Torque Flight trans problems Steves66 Transmission - Rearend 5 06-30-2006 04:11 AM
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 07:27 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
