I like the keep it simple philosophy, the fewer moving parts the better (to me).
Yea, and one question still not solved: with transfer case or without? |
Its really a question of what xfer case you want to use, along with what engine/trans combo and then getting it all to fit. |
If the vehicle started as front-drive, then there is the new tunnel required and the completely new rear-end. I'm moving from AWD to RWD, and thus have the tunnel, however the rear is basically useless as I was originally splitting 210 tq two ways, and now i'm looking at 300+ tq one way. Either way, a fun project you will have! |
The 66-85 or so Eldorado/Toronado setup has the torque converter on the engine in a bell, with a wide chain from the converter output to the transmission input. The transmission is on the left side of the engine and points forward, with the differential on the end ("front"). The right axle goes under the oil pan. The engine ends up centered over the wheels. Early models with the big 455/472/500 engines use a TH-400 derived transmission, later models with 350 and smaller engines use a TH-350 derived transmission (I've been told TH-325?). Here's a link from when the Toro was introduced that covers all the details: http://motortrend.com/roadtests/clas...ng/index4.html
Note that this could not be used in an AWD configuration. |
| Hotrodders Guidelines -- READ ME | Jon | Suspension - Brakes - Steering | 0 | 06-14-2003 05:03 PM |
| Hotrodders Guidelines -- READ ME | Jon | Body - Exterior | 0 | 06-14-2003 05:00 PM |
| Hotrodders Guidelines -- READ ME | Jon | Interior | 0 | 06-14-2003 04:59 PM |
| Hotrodders Guidelines -- READ ME | Jon | General Rodding Tech | 0 | 06-14-2003 04:57 PM |
