-   -   Awesome budget 400 sbc block builds (http://www.hotrodders.com/forum/awesome-budget-400-sbc-block-builds-221818.html)
Uniryan2008 07-17-2012 04:06 PM
I've my next build up in the air all I know is I'm starting with a small block 400 whats a good idea for goin kinda budget but get good power for the time I will have to put in?
68NovaSS 07-17-2012 09:11 PM
How much is "kinda budget"? You need a goal, power wise, what's the intended use, what vehicle?
cobalt327 07-17-2012 09:30 PM
You can use this to help you come up w/a question we can answer.;)
Uniryan2008 07-17-2012 09:32 PM
Most likely my '81 gmc long bed,I didn't wanna go aluminum heads jus maybe forged rotating assem.,non roller motor,I want it reliable that's very important for the build,but so is power.
Uniryan2008 07-17-2012 10:00 PM
I'm lookin for at least 400hp but a lot more torque than that would be nice
vinniekq2 07-17-2012 11:07 PM
cheap 400 I built for a friend. 1978 monte carlo, 20 plus miles to the gallon when right foot is restrained and 14.1 1/4 mile times with 2.73 gears and white wall radials.turbo 350 with shift kit,stock converter.
Bone stock short block rebuilt with cast pistons and static balanced,stock heads.Mild 430 lift flat tappet hydraylic cam,street master manifold, 625 carter carb,1 5/8 primary headers,2 1/2 " dual exhaust not mandrel bent. no where near 400 HP,but a tonne of torque. tire melter
Uniryan2008 07-19-2012 06:53 PM
How about a 400 with a 3 inch stroke, what can be done with this combination ?
vinniekq2 07-19-2012 07:33 PM
400 destroked
how about a bill Mitchell block with 4.25 bore x 3" super light crank making 340 cubes and SB-2 heads?
Uniryan2008 07-19-2012 07:37 PM
That's sounds pretty sick, how's that run?
327NUT 07-19-2012 09:05 PM
Why in the world would you take a 400 and put a 3" stroke crank in it if you want a lot of torque????? Abosolutely makes no sense and Vinniekg2 ???? the guy said he's on some kind of budget and you're filling his head full of Bill Mitchell block $$$$$. Do some reading Uni and stop dreaming.
cobalt327 07-19-2012 09:12 PM
Originally Posted by 327nut (Post 1575326)
why in the world would you take a 400 and put a 3" stroke crank in it if you want a lot of torque????? Abosolutely makes no sense and vinniekg2 ???? The guy said he's on some kind of budget and you're filling his head full of bill mitchell block $$$$$. Do some reading uni and stop dreaming.
http://www.thirdgen.org/techboard/im...milies/yup.gif
vinniekq2 07-19-2012 09:19 PM
mr nut,there are a few threads that are going no where.I should not have posted that but was frustrated because I was truly trying to help with the previous posts I made.
Uniryan2008 07-19-2012 09:28 PM
I would jus like a few pointers on 400 builds,I'm not goin to diss anybody's knowledge a lot of people have done a lot of things and I enjoy discussing those times had ,that's how I learn all my knowledge since I started building sbc's and so fare been successful, thanks everybody
my87Z 07-19-2012 11:34 PM
if all you are looking for is a 400hp sbc 400 then dont bother with forged internals. if you can find a complete 400 (good luck!), tear it down get what ever machine work needs to be done to the rods, crank, and block done. buy a set of 18cc dished pistons, a mildly price set of 200cc runner/ 72cc combustion chamber steel heads (should put you around 9.4:1). get a hyd f/t cam with somewhere around 220-232 duration at .050, dual plane intake, 50-60k volt cheap HEI distributor, 750 vacuum sec carb, $250.00 set of headman headers, 2.5" exhaust and some decent mufflers. it will want atleast a 3.73 gear in a truck if not a 4.10 and it will probably want around a 2800-3000 stall.
bam! simple 400-430hp (easily) 440-460tq (again easily) motor that will be rather easy on the pocket.
327NUT 07-20-2012 01:16 AM
Vinnekg2......PM received and PM sent back, I understand completely and no problems whatsoever........Dave
