To rule out the problem being electrical, then check your wiring and your ignition switch. Not a big deal, just disconnect the S terminal wire, hook a volt meter up to it (positive on wire and black to a good ground), turn the ignition to run and start playing with the wires and wiggling the key as you watch the meter. If it is in the wiring you will see the meter twitch (be sure to set the meter at no more than a 12v scale).
As far as the starter, you could pull the solenoid off and replace the spring with a good used one. I am sure you can find someone with one or check at a shop that rebuilds starters. If the y lever is worn it may be the problem. You could also take the whole starter to a shop for inspection. |
Easier than that...
Doc here,
To rule out the electrical, just start it and remove the "S" terminal from the solenoid period, then warm or drive it...If it comes back it's not electrical... Most likely it';s The starter drive unit (mechanical ) It self... Here is what it looks like: ![]() The Problem will usually be in the starter drive unit... Electrically, the only thing that will cause this would be a HIGH transient Voltage down the "S" line to the Solenoid...and I should think you'd be having other electrical problems then what you have now. Are you Sure the Throw out bearing hasn't locked up or shattered? Does the noise Go away when you step on the Clutch? Return when you release it?...Just another thought in "The Big Picture"...Maybe A broken Clutch "Finger" striking the TOB... Anyway, look at the starter Schematic and Repair or replace as needed, and if all else fails try the Throw out bearing and / or pressure plate...(I know they are new, but new stuff gets broken too...) I Do however Doubt it's an electrical problem... Doc
Aftermarket Solutions Electronic & Electrical Innovations |
At restarting time the grinding wouldn't be on immediatly but had to wait a short time before it would grind again... I'll sleep on it and see tomorrow what it will bring but looks like I will opt for a rebuilt unit and shove it in and see..the idea of taking out the S lead after the engine is running sounds simple and cost effective! thanks,Ronald. The fork is at his position and the throw0out bearing "looks" O.K. altough I can't spin it manually of course. |
| grinding noise (awfull..) | TVR383 | Engine | 7 | 05-23-2005 08:39 PM |
| Knocking noise, HELP! Please!! | fireforsin | Engine | 4 | 01-04-2004 11:31 AM |
| Grinding noise | yogunna123 | Transmission - Rearend | 0 | 09-30-2003 05:45 PM |
| valvetrain gurus: need help identifying mysterious valve noise | blndweasel | Engine | 10 | 03-04-2003 07:59 PM |
| th-350 clanking noise then grinding the nothing | roadrash9r | Transmission - Rearend | 8 | 12-09-2002 03:32 PM |
