axel coding question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 03:19 PM
1996thunderchicken's Avatar
ALL AMERICAN MADE
On my 1977 nova I was trying to find the casting number but the only number I found eell could find was 12345 and thats it
Old 07-22-2012, 05:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That's not a useable number. The casting numbers will tell you the basics, but the codes usually found stamped into the axle tube will be more specific as to what the rear end was originally in.
Start by finding out the rear end type. In your case it'll probably be the 8.5" corporate 10-bolt. From there, find the codes stamped into the axle and take a look here for links to what they mean.
Rearends got changed a lot through the years, so the ratio from the stamped code might not be what's in it now. To find the ratio now in it you can take a look here.
nova, rear end identification
De-coding my 454 engine numbers BigD454 Engine 2 08-03-2010 04:39 PM
Contradictory Chev Engine coding, 305 or 307? kahl_454 Engine 6 01-15-2010 07:47 PM
coding without a clue grouch Hotrodders Site Suggestions and Help 6 03-12-2007 09:51 AM
rack and pinion kit for straight axel question Slickriffs Suspension - Brakes - Steering 5 01-14-2007 11:05 AM
Date coding GM starters? zmanan Engine 0 10-21-2006 09:32 AM
